Hi all, well it looks as though I'm going to have to replace the track control arms on my 2000 2.7, just checked them and there seems to be quite a bit of play in the drivers side one. Does anyone know the best place to purchase them and what the correct part number is?
While trying to find the sight glass for the A/C (unsucessfuly, does it exist?) I noticed that the cabin filter doesn't seem to have a cover over it, should it have? All replies gratefully recieved.
Thanks guys, any one know where the A/C sight glass is. Is it likely it can be anything other than a leak? fuse?
It's my understanding that once you remove the plastic shield that allows you access to the cabin filter, you'll notice that the filter has no cover. It just sits in it's housing without anything covering it. It's easy to swap out as well due to this fact.
Hope this helps,
Jay
02 986
90 911
84 911
