Hey folk, The other day my boxster became a very rough sounding and hesitatent thing. I plugged in the fault finder and turns out that cylinder 2 is mis-firing. Am planning on replacing the ignition coil but i am a bit unsure where cylinder 2 is? is cylinders 123 on the left hand side or right? and does anyone know if this is a tricky job for an non diy person like myself? does anyone know of any instructions on the internet for this job? many thanks
I believe Cyl 1-2-3 should be on the passenger side. Replacing a coil isn't hard - just pulling off the elec. connection to it, and two bolts to hold it on. If you do a search here, I believe Loren commented once in a thread on how to check the coils. Using a VOM, you can go across two pins and measure a value (resistance I think it was) to determine if it's really the coil that's bad. I don't remember exactly the procedure or nominal values, but if you search here, you should find the thread.
--Bill
Found it for you. From an older post by Loren:
"They can be tested as follows:
Check the resistance across pins 1 and 15 (black wire and green wire w/stripe -- not brown).
Resistance should be 0.3 to 0.7 ohms at 20 degrees C."
