The Key Fob for my '01 Boxter went dead. I replaced the battery but it still doesn't work. Is there a re-set procedure or do I have to spend the $$$ to replace it. :o
:welcome:
Please give our Search a try as this has been covered many times over.
Reverse the battery for a few seconds - then put it back in the same way.
If that does not work then either the circuit board inside the fob is worn out or somehow it has lost it's program.
You can try to get a dealer to reprogram the key (they will charge you for this) or replace the key and have it programmed (again at a cost).
