Greetings. 2001 Boxster with 36K miles. Bought it used, and last night got around to bleeding brakes and crawling around under it. The engine/tranny is pretty much spotless, no leaks anywhere that I could see or feel, except for around the plug coils.
With the rear wheels off, to the sides, and under each plug coil (both sides of the engine) is a bunch of oily schmootz that can be wiped away. Nothing on top of the coil packs though. No noticable oil consumption since I've owned the car (about a month), and it's never marked it's territory on the garage floor. :)
Leaking plug tubes my most likely culprit? Should I just wipe it clean and see if it is an old issue that was never cleaned up? Or with 36K miles, is this just a quirk of our beasts with plastic plug tubes?
Bill
you probably have the older version tubes. Buy the new part numbered ones and replace. Easy writeup here, do search and have at it.
