You can bridge the temp sensor ( ignition key on or engine running) located in the top of the oil cooler and see if the fan is sound or drive the car up to temp then idle it until the fan comes on. Temp gauge reading of approximately 3/4 should bring the fan into play.
thanks, found an article. You can jump number 30 with 87 and 87a on the relay and run the fan at each speed. Got it hot and it worked.
