Can the AOS be the problem of the coolant drop and Why?
I had coolant drop and i dont have smoke.My oil seem to be clean and no trace of oil in coolant.
I replace the coolant cap and refill the coolant and the coolant drop again.
I dont see any leak.
The engine works well and the température is ok at 180.
Where the coolant goes?
Targa 2003 996 3,6l
Manual 6 speed
Us car
Edited by elgrand
Probably a small ordinary leak somewhere in the cooling system, you need a device to put some pressure on the system, the leak will be visible. 996 AOS is heated but a leak is uncommon.
How much coolant are you having to add? It could be that the old cap purged some out, also check at the front of the vehicle as that is where the cooling radiators are located.
Last time i add about 1.5 liter of coolant and i update the cap of the tank.(Number finish by 03)
I will try to find a tool with good adapter to put presure on the system.
Thanks for reply guys..
I am in Québec Canada and my car is us.
I just recheck for leak with engine at 180 and no leak in front and to the rear.
Is that possible that i have some air in the system and the air take place of the coolant
in the tank.?
Edited by elgrand
