Porsche fault code 93 - Tank vent system
34
Interior sensor faulty
what do these mean...
P0455 Fuel Tank Ventilation System (Major Leak) - Below Lower Limit
Potential causes:
- Tank cap missing (or bad o-ring seal).
- Ventilation lines detached from EVAP canister.
- Ventilation line detached from tank.
- Ventilation lines detached from operating vent valve.
- Ventilation line detached from fuel tank vent valve.
- Break in ventilation lines.
Fault code 34 - Passenger compartment monitoring sensor, short circuit to B+ or faulty
Potential causes"
- Short circuit to voltage in wiring between the alarm system control module and the passenger compartment monitoring sensor
- Passenger compartment monitoring sensor faulty
