:welcome:
Model and year of your car please?
And... did you install the turbo cluster?
The year and model of my is cayenne S 2006 and i install turbo cluster but i dont know why have this problems :angry:
well, if you own a non us-spec cayenne and if your cluster is from a us-spec cayenne, it will not work.. DME's of the european and us cayenne's are different. I bought a turbo cluster from ebay but it appeared to be from a us spec cayenne, so when we tried to install, we got the same faults as you do. It won't work, don't waste your time, sell it and try to get a proper one.. (i know it is hell diffucult)..
Or if you own a us spec car and got the european cluster, it won't work either as the same reasons above, but i might be interested if you want to sell it. . :)
btw, where did you get it from ?
Edited by tuki
Cayenne clusters till MY 04 have the "gateway" build in, from MY 05 the "gateway" is separated (under the dash).
i just talked with a mechanic from a p-service, I asked about the same that you wrote, he told that even you have the same gateway version, if the specs are different, it won't work.. what a bs.. :(
hi and thanks, i was thinking about that before buy the cayenne turbo cluster, my cayenne S is european and my cluster is in KM/H and the turbo a buy is in MPH.
the cluster i get is from a cayenne turbo 2004 they was crashed in US today i delivered to NY BRONX to a friend to sell it, if you are interested you can send me a message for contacs. thanks
Loren,
could you help us in this case. I couldn't get a clear answer from my service mechanics.
I have a MY04 Cayenne S, European Spec..
And daurys cluster is from a MY04 CTT, US Spec.. I guess both have the gateway buildin..
will it work in my cayenne ?
(the service says that eventhough the gateway versions is the same, it won't work because of the different regional DME's.. I'm confused.. :()
Hi you think if i buy 2005-2006 CT cluster us spec to my CS european is going to work?
Hello Loren;
I am having a similar problem also.
I have tried to install a 2005Turbo Cluster to my 2008 Cayenne S but it totally did not work?
Both cars are from same region and country!!!!
Any idea please?
Thanks a lot.
Mohamed Saeed
Hello Loren;
Any idea please?
Thanks a lot.
Mohamed Saeed
Did you follow the instructions here
  • 6 years later...
I have an 06 cayenne S (US) does anyone know where I can buy a used turbo cluster for it? I hate the mono Amber one I have.
Ebay occasionally has a turbo cluster. It is possible to retrofit if your immobilizer is not part of the cluster (like 04's and not certain on 06). May require a reprogram with durametric and odometer is locked so that adds a little glitch when resale as may need to list as miles Unknown.
