Hi - does anyone know the part number for the high pressure intake AC line which runs under the passenger side of the car? It's a thick pipe which joins another pipe just infront of the rear wheel arch. The front of the pipe curves up through the passenger side wheel arch coming through a hole in the body. Mine has a hole and I need to source a replacement. So it runs from the rear wheel arch to the front wheel arch and curves upwards as one piece.
Thanks for your help,
Andrew.
