Hey there.
My check engine light came on in my 2000 Boxster S. I had my neighbor hook it up to his computer and It came up Mass Air Flow Senor with the following codes:
P0102 Mass air flow sensor
P1126 Oxygen sensing adaptation, lower load range, bank 1
P1128 Oxygen sensing adaptation, idle range, bank 1
P1130 Oxygen sensing adaptation, idle range, bank 2
P1133 Oxygen sensing adaptation, lower load range, bank 2
Has anyone ran into this problem? If so is it an easy fix or something I need to take to dealeraship? Any information would be appreciated. Thanks
P0102 says your MAF is open or not connected - start there as it could cause the other faults.
Thanks man. Im checking it out as we speak
