There should be a tool in the trunk kit to hold the pulley while you remove the nut (if not a long handled screwdriver will work too).
After you remove the nut and large washer the pulley half will come off and you will see shims to use to tighten and loosen the belt. A little trial and error is needed but basically fewer shims (inside the pulley) make it tighter and more shims make it looser.
How do you tighten the alternator belt on an '86 911?
Try two shims between the pulley halves.
It works for our '86.......
