Loren,
I'm moving the AC control from here..
to here..
I just wanted to be sure the dealer order the right bracket... and is ther anything else
needed for this move?
Well I moved it... the easiest way to to it is remove the side panels on the console. that makes it easier to get the wires.. Also you need the new cover that goes around the AC control unit.. $5 part #996 552 339 00
No other brackets are needed.. there is actually 2 holes for the AC unit to screw into this location.
