Curious if anyone's seen this.
Idle at stop and she throws the CEL with PSM, ABS light
Pocket reader says nothing.
At re-start, nothing....all fine.
Any thoughts welcome.
Thanks in advance.
Pocket readers will not pick up all fault codes.
Check your brake lights (for PSM/ABS light problem).
Find someone with the Durametric software, a PST2, or PIWIS tester to read your car's faults.
Yep thanks.....shop has PST2, I'll get her in.
Mine used to do that especially after a hard run and when I'd come to a stopsign....on would come the ABS/PSM...ended up being a MAF.....the dealership ate it under a CPO, probably as a favor...and I've had no more CEL's since then.
