hello,
I have a Cayenne engine M02.2Y (3.2) with cooling problem.
Neither the big nor the small electric fan for cooling starts. The A/C compressor runs for a while then stops because of the high pressure/ high refrigerant temperature and the fan activity missing. The big one, controlled by the engine unit doesn`t make any move also. Which could be the odd both of them to be damaged? Very small one I think.
P.S. both of them have DC 12V and good Ground.
So, did any of you encountered this problem? Should I start by replacing both fans? This costs me and I`m not sure if the fans are damaged.
Read out the fault codes with a diagnostic tool (PIWIS or similar), the best and cheapest way to go IMHO.
