I recently bought a 2002 Carrera (April) with the memory seats. From day one since I have owned it the mirrors invariably change positions when I get in the car after being locked with the keyless remote and then re-opening with the remote. I have tried both the memory for the key and memory setting 1 or 2. Any help would be most appreciated. :renntech:
Check the manual. When the memory is set with the gear shift in reverse it will move the mirrors on first backing up. Best to reset all of your keys.
I have programmed per manual. I had a Benz that would rotate down in reverse depending on the mirror swich, I do not like that and did not program while in reverse. I just re-programmed and after a few locks/unlocks so far so good. However, it acts good at first then begins re-positioning the mirrors (both sides) on a whim.
