Hello All,
A while back I completed the OBC Hack in my 1997 Boxster using two switches in the dash instead of going the stalk route. After a little trouble at first, the mod has been working well with no issues. I would like to have the switches light up when I turn the car's lights on, similar to the rest of the switches. Does anybody have any ideas where I can get the appropriately switched voltage to add to the lamp pins on the back of the switches?
Fulcrum
This depends on which switch you are using. If you are using the footwell lighting switch the only way to get illumination is to replace the switch, or hack it. A search should turn up some more information on this. I decided not to bother with this, and have no problem finding it in the dark.
