Car decided to play up last week due to a flat battery.
Deduced through a voltmeter across the battery that the alternator/vr had failed as there was a reading of 12.8v with engine off and 11.8v with the engine running. Quicky followed by flashing dash lights, erratic spoiler etc
So 3 days in a car garage, 30 miles and approx £680 later!!!!! (inc new battery and new alternator) have exactly the same problem,
Having not carried the work out myself is the voltage regulator integral to the alternator would it be exchanged (provided) with the new alternator.
I am furious with myself for not checkin the voltage readings having received the car back from the garage to see it was all working.
If the VR and alternator were replaced as an integral item and are presumed to be "okay" when fitted is there anything that could cause either the new alternator/vr to fail due to the cars operation?
Edd
Edd
Bad grounds can have similar symptoms. I had a vanagon once with a bad ground to the starter that did the same thing. Your assumption was correct in thinking the VR and I would not have replaced the entire alternator as I though the VR are on the outside of this unit, but I could be getting my cars confused too!
