I have a 2000 Boxster 2.7 Tip. I have a flute like whistling noise which emanates from between driver and passenger, to the rear. It is gas pedal sensitive and can be heard at its loudest when just idling. It never does it from cold. As soon as the engine reaches normal operating temperature, it starts. My local OPC changed the fuel pump and it stopped for 3/4 days, but now its back with a vengeance. I desperately need ideas and suggestions.
Sounds like the 'whistling ventilation valve' post about 8 posts down.
I'm waiting for someone to explain that one.
Since it only happens warm, you might pressure test your (water) radiator cap. It is a long shot, but it should be a free replacement under recall if found to be defective.
