I have a MK2 996 with a reman engine.
I'm curious to know how one can tell if it has the latest IMS bearing design (dual-row) v. the single row in the MK1 3.4s.
Do all 3.6s come with the dual row from '02 onward? Can you tell by the engine #?
Benjamin,
I have heard that all the 3.6 remans have the new bearing upgrade. I'm sure Jake Raby would know for sure. He might be a good resource.
Edited by phillipj
The dual row IMS bearings were mostly on the earlier M96 engines, but it is impossible to be 100% certain without removing the transmission to visually inspect.
IIRC, there is a website that gives engine #'s but it is not completely accurate.
Go to the LNEngineering.com website for details.
Regards, Maurice.
So did I have that reversed? The newer design is a single row (simpler, less parts) than the older design with double?
Ben:
Yes!
I don't think it was for simplicity or for less parts. They knew they had a problem and have tried various fixes.
That said, if it was cheaper to use a single row bearing, Porsche would not hesitate nowadays. :soapbox:
Regards, Maurice.
Ben:
Yes!
Regards, Maurice.
Dual row bearings are on the earlier motors, single row on the later motors, as previous posters have said.
On LN Engineering's web site, there is a page devoted to the retrofit. On this page, you will find an approximate range of engine numbers for each. There is also a visual way to confirm, if you have the transmission and clutch separated from the engine (obviously not very practical) detailed on that page. Here's the link:
http://www.lnengineering.com/ims.html
Regarding Maurice's comment, I think Porsche is actually much better about this stuff 'nowadays'. However, when the 996 was designed, they were in financial trouble. It shows. It's one reason I have some affection for the car, in my perverse way. The 993 was a transition car that bought Porsche some time, but the 996 literally saved the company. When you consider the impossible circumstances they were operating under, the 996 is a really remarkable car in a lot of important ways. Cheap in spots, for sure (the IMS was a way around having to create separate castings for the right and left heads, for example). But the engineers had their hearts in it. Just my .02 worth of editorial comment. :D
Cool perspective, BP.
+1!
Regards, Maurice.
