Tiptronic Fluid Change
Hello...could someone PLEASE direct me to a site or to a technical service manual or something similar that explains how to change ALL of
the fluid in a tiptronic transmission? I need to learn how to change the fluid in the torque converter and differential.
I've searched...and can't find what I need.
Cheers
Mike
Cheers
Mike
Try this link.
Paul
http://www.renntech.org/forums/index.php?showtopic=6203
Thanks Paul. I have seen that DIY article. It doesn't mention a full fluid change...just a filter and pan gasket.
Thanks.
Mike
Why (if you don't mind me asking) do you need a complete fluid change?
That is normally done at rebuild and complete disassembly.
I don't mind you asking at all...
I want to do some maintenance is all, maybe prevent a failure.
I think of the "lifetime" trans fluid the same way I think of the lifetime coolant.
The way I see it, the car is almost 9 years old and has 64000 km. on the clock.
Probably a good idea to change the fluid.
Am I being ridiculous?
Cheers
Mike
Cheers
Mike
If you just do a recommended ATF change on or before schedule I think you will be fine.
Technically you never get all the oil out of the engine either.
