I'll see a friend tomorrow night that have a PST2 and would like to know if with that tool we can switch the HVAC temperature readout from F to C? If yes where in in the DME we have to go?
Tks all!
Well I knows Its a different system, but I read somewhere on the standard digital a/c unit, if you hold down the re-circluating air botton and then press the up and down button to toggle between F and C.
Not sure if this is the same as what your talking about, but hope it helps!!!!!
This manual process is for older that 2003. Mine is a 2003 so the HVAC toggle don't work.
Just an update. Job is done.
We did use the PST2 and change country from USA to Canada and all imperial data's including the HVAC in deg. F. readout goes metric.
Thank you all.
Thierry
