I am disassembling my rear suspension to install my ROW030 suspension kit and I notice the grease bushings on my rear ball joints are all torn up. I suspect the body shop that repaired the car couple of years back used a pickle fork to separate the ball joints rather than a proper ball joint lifter. Can these ball joints be replaced without replacing the whole track control arm? I don't see how they can be removed, but I am no expert and I might just be missing something.
If they are the same as the front ones (I know that one of them is) - then the ball joints are not replace-able - you have to replace the whole arm.
Mike.
