2001 C2 with 80K miles
From another post:
P1126 Oxygen Sensing Adaptation, Lower Load Range, Bank 1 – Above Limit
P1133 Oxygen Sensing Adaptation, Lower Load Range, Bank 2 – Above Limit
Potential causes:
– Incorrect signal from MAF sensor
– Intake air system leaking
– Fuel pressure too low
– Volume supply of fuel pump too low
– Fuel injectors fouled
P1130 Oxygen Sensing Adaptation, Idle Range, Bank 2 – Above Limit
Potential causes:
– Exhaust system leaking
The problem is not your O2 sensors.
The first place to start is the MAF.
Your mechanic should know he needs to look at the MAF readings at idle and 2500 RPM. If there are not within spec then the MAF needs to be cleaned or replaced.
I have the codes P1126 and P0102.
Durametric readings on MAF are:
Idle (~780rpm) - MAF ~ 17.2 to 18.4 kg/h
~2500 RPM - MAF ~49 kg/h
Any thoughts on if these are in range, or a place to narrow these down?
Mark
From another post:
Potential causes:
Potential causes:
Mark
Looks pretty close. Have you tried cleaning the MAF?
(chart below is for MY2000 and up egas 996 cars only)
From another post:
Potential causes:
Potential causes:
Mark
Cleaned it today, codes have not returned. I will keep an eye on it. Thanks Again.
Mark
From another post:
Potential causes:
Potential causes:
Mark
Mark
Well, the codes are back. After cleaning the MAF sensor with CRC MAF Cleaner, and driving at highway speeds (on way to a DE track day, kept going, car did well...) have the following codes read with Durametric:
P1126
Porsche fault code 356 - Multiplic. mixture adapt.
lower load range B.1:
P1133
Porsche fault code 358 - Multiplic. mixture adapt.
lower load range B.2:
P0102
Porsche fault code 115 - Mass air flow sensor
below limit value
P1125
Porsche fault code 357 - Multiplic. mixture adapt.
upper load range B.1: exceeds limit value
P1132
Porsche fault code 359 - Multiplic. mixture adapt.
upper load range B.2: exceeds limit value
Time for a new MAF sensor?
Mark
