Is there a difference between Super Dot 4 and Dot 4 brake fluid? All I could find on the shelves is Dot 4 brake fluid rated for 478 F. Is synthetic Dot 4 brake fluid adequate for 2001 Boxster S? If there is a difference between Super Dot 4 and Dot 4 what is it? Thanks
It's just a question of boiling points. Any DOT 4 fluid will be fine for driving on the street, but for $13 why not buy some Ate Super Blue or Typ 200 (gold)? It's a great brake fluid which stands up to hard use at the track. It has a dry boiling point of 536 degrees and a "wet" boiling point of 388 degrees. This qualifies it as a Dot 5.1 (or "Super Dot 4") fluid.
http://www.livermoreperformance.com/brake_fluid.html#ate
Check out this link for more info on different types of brake fluids: http://www.stoptech.com/tech_info/wp_brakefluid_1a.shtml
