Hopeful that someone out there has done this upgrade and can provide a few pointers before I tackle this project. I track my car occasionally and will be changing out the original brake fluid for Motul 600 soon. While there I figured I would swap out the OEM brake lines as well. I do realize after a little research that this is probably not necessary and I shouldn't expect a huge performance difference but I've already bought the parts and I enjoy doing it.
My main concern is not getting the old brake fluid everywhere. Should I drain the system first?
I have acquired a Motive Bleeder and catch bottle, plenty of Motul fluid, and the flare nut wrenches mentioned in other threads.
Any tips would be appreciated. Thanks.
The brake bleeder works real good. I would
replace all the lines at one time. Then bleed
the farthest brake first. Piece of cake.
Paul
