hello everyone I have a 1990 C2 Convertible LHD and it will not start unless I run a live wire from the positive battery terminal to one of the pins on te dme relay in the fuse box ???
the live wire stays thier contiously in order for the car to run, The car is a project car and I dont quite know the history on her.... Is it possible that if the hood motors which are currently disconnected for the soft top would cause a problem where the car will not start because it thinks the hood frame is in open half way position or something or am I barking up the wrong tree here???
any help would be great all the obvious things have been checked fuses fly whel sensor coil packs fuel pump etc the car gets fuel but no spark the spark is disabled I have even tried testing the ecu in another car and it worked fine ....
any help would be great thier is a bunch plug next to the main ecu with nothing connected to this I was wonderin if that is causing the problem but not sure I aquired the car as a non runner but have manged to get it going by the qbove method...
your suggestion are most welcome on the topic
many thanks
Zak (UK Birmingham)
think I cracked this one as well
all 964 cabs get water inside them at some point this fact even if it is dry stored when you wash the car some water ingress is invetible
any hows passenger front footwell you have the main wiring loom going to the ECU this loom bends at a roughly 90 degrees angle at the corner of the footwell where it proceeds up the bulk head along the top scuttle wiper motor area to the fuse box ... the exact route I am not too sure on as this is guess work
but where it bends say 45 to 90 degrees on the floor along the sill area and front bulk head is a water prone area i.e if the foot well gets wet that area will accumulate water this inturn can over time cause the loom to get damage and even a short break in one of the wires can cause an implausable signal ... etc
so I think after I have carried out test for breaks in this loom I should have sorted it ....
will update in 28 days this is how long it sometimes takes me on my project cars lol .... I just dont get the time to work on them ... I guess if the 996 C4 Cab was not about I would have got the 964 sorted by now ...
