I just bought a cayenne turbo 2003 and while i was speeding the temperature started rising and went over 80 is it ok?
How much over 80?
Have you checked your coolant level at the reservoir bottle?
Edited by bigbuzuki
How much over 80?
Yes it going over 80 3/4 temp mark....Nopes i have not checked the coolant level
I just bought the car 2 days back...
If the temp goes up while you're at speed, it could mean clogged radiator, low coolant, dirty coolant, dying water pump or bad thermostat.
If the temp goes up while you're sitting still, it usually means bad thermostat or dead radiator fans.
If it were me, I'd check the coolant level and do a pressure test on the system for leaks.
If that all checks out, I'd try a coolant flush and replacing the thermostat.
Thanx for your help.
I have asked for porsche ppl for a visit.
Lets see if they are able to figure it out....
Thanx.
