Cayenne GTS/Turbo front bumper upgrade
So, After a productive Easter break I have upgraded the front of the Cayenne `S' to look like the GTS/Turbo model. Always thought the bigger front grille made the car look more `planted'. The attached deck shows the steps I went through if anyone else fancies trying the change but would alse be helpful for any mod that requires the front bumper to be removed. I also installed the front steel skidplate while upgrading the bumper and will post this as a separate guide shortly. Any questions or
Edited by jamesevelynclarke
  • Like 1
  • 3 years later...
Excellent tutorial.
Does anyone have the part number list for the various bits and pieces shown (bumper, grills, side/signal lights, blanking panels, etc?) Or maybe a parts diagram I can get them from?
I have found the list for the 955 but not the 957. The 957 seems to require less parts than the 955 judging from your instructions. My CS has the headlight washers and park distance sensors so that should be plug and play.
The GTS/Turbo front bumper does look much better.
John
  • 7 years later...
