I had aftermarket xenon's put in my Cayenne S (04) about 6 months ago and today the headlight, high beam and signal on the left side stopped working...do all of the bulbs usually go at the same time or does this sound like a voltage issue?
My first thought would be to check to be sure it is properly locked in place. Look in the manual for procedure and be sure you feel/hear the "click" that it did lock down or you could lose the assembly if you make a quick stop. Good luck!
