what is the proper procedure to check the oil level ? thank you :renntech:
ps
Just did my oil change at jiffy lube and they put mobile 1 5w-30 into the engine . I am in troubles ?????
Edited by zgdanska
Check the owners manual for the oil level check procedure. Jiffy Lube? Are you kidding me? Do you know how much a new engine costs?
I also take my '99 996 Cab to Jiffy Lube, but I bring my oil and filter. I'm friends with the manager, so I get to supervise the process. I use 5w40 though.
ps
Porsche does not approve 5W-30 oil for it's cars. 0W-40, 5W-40, and 5W-50 are approved oil viscosity.
You really need 5W-40 as a minimum.
  Loren said:
ps
For whatever reason, the Porsche dealership near me (Birmingham, AL) uses Mobil 1 0w30. Same guys that let a Cayman S basically rot on display at a local mall--completely rusted calipers and cobwebs all over it.
Just found the cd with the manual and looks like they overfill the engine by almost 3/4 liter .(i ran the car for 20 min , then park in garage and waited 5 min ) I will go to them change the oil to 0/40 and fill only with 8 cans for now . :renntech:
ps
To Loren
I have 53000 miles on this car . 2002 cabrio 911 996 3.6 non turbo . What will be the best choice of oil ????? Thank You always for your input.
Edited by zgdanska
hmmm , this is from the manual
above 50F
15w40 10w40 20w50 15w40 15w50 20w40
below 50F
15w40 10w40 10w30 5w30
below 14F
10w30 5w30
i don't see any 0w40 5w50 . Any help with that ? or maybe the manual is outdated ??
ps
To Loren
The factory fill is Mobil 1 0W-40. Most owners use that or 5W-50 in either Mobile 1 or Castrol.
  zgdanska said:
why this two are not in the manual ?
There is a Porsche TSB (available on this site) which updates the list of approved oils.
Manuals do not get updates - TSB are for that.
My MY1999 manual says 15W-40 Mobil 1. Which I am sure works but Porsche has removed it from the "approved" oils list. 4-5 years ago as I recall.
