Hi there,
I am replacing the pass. side window regulator and need to know the part number for the thin plastic film for waterproofing, sometimes called foam (actually don't know if it is plastic or not, it is the one that everyone cautions to be careful removing, held on with buytl). Also if there are any other items I should replace like the plastic tabs that hold the door panel on please let me know also.
I also need the battery cover, washer for the spare tire holddown, and the little lens that goes on the little hold down area for the top, the place when the latch pulls the top down, it's about an inch long, half inch wide, one on either side.
2002 C2 Cab, seal grey, US model
Thank you
Edited by venturawildes
996.542.076.04 Right window regulator (same part for coupe, cab, and Targa) -- US MSRP $218.82
Perhaps the plastic is 000.043.204.38 Sealing material -- US MSRP $22.29
The plastic tabs are either grey or white - I think you need to check your old ones first because I think the size is different.
999.507.505.40 Grey clip (8 required) -- US MSRP $0.38
999.507.582.40 White clip (8 required) -- US MSRP $0.38
477.813.157 Fastening plate (washer for spare) -- US MSRP $19.73
996.572.567.01.01C battery cover -- US MSRP $13.78
you may also need 999.590.045.40 Screw plug (hold down for battery cover) -- US MSRP $0.77 each (2 required)
Sorry, I don't see enough Cabs to know which part you mean - can you take a picture and post it?
Loren, you are amazing, thank you. I will post a pic of the other part when i get home.
Loren, is the sealing material the buytl cord or the film?
