Hi
My 3.4 engine blow up, and I found a boxter cheap 3.2 engine (for spare parts).
What differences there are between those two engines, i.e which parts I CANNOT USE? I think I´ve seen somewhere that the engine block is different...but I can´t remember. I did a serach, but couldn´t find the messages anymore.
Thanks guys!
Kare
Lot of people go the other way and put a 3.4, 3.6 and 3.8 in their BoxsterS that comes with a 3.2 The 3.4 is a bored out 3.2. You will lose HP and have to swap over a lot of components. Why not go the other direction? A 3.6 or 3.8 to get more power while you are doing the work anyhow.
Hi
Thanks guys!
Kare
Hi
Thanks guys!
Kare
I´m going to rebuild the 3.4, as it is installed into my MY98 Boxter.
