HelloI need some help. I have this clunk noise on the front of the car. Cant tell if left or right. I lifted the car on a lift, all suspension rubber parts are good, I shacked everything underneath including both tires nothing makes noise. What could it be?? 01 Boxster. Thanks Angel...
You might post the mileage and some of the service history(ie shock replacement, etc. ). Having said that, you might check the front strut mounts/bushings. I'd also check the sway bar link and bushings. It worth checking the driveline mounts, we've replaced all of them on our 01 at 50k. They produced alot of vibrations and clunks.
Regards
Check your trunk for anything rolling around. Other wise tell everyone under what circumstances it occures.
Regards PK
