The exterior aluminum trim on my 04 CS is starting to look stained and dirty. Normal soap and water do not help, and nor does Mother's aluminum cleaner. I was wondering if that is because the trim pieces are clear coated.
Joost
  • 2 months later...
I have the same problem. I used aluminum cleaner and it worked for a day or two .. then the stains came back. Any suggestions????
Those brushed aluminum trim pieces are anodized. The problem is that almost anything you do to clean up the surface, especially if abrasive, will remove the anodize coating. This leaves the aluminum surface open to oxidation, which happens within minutes; and results in more staining.
To completely eliminate the stains, the part(s) need to be stripped and re-anodized.
Edited by DUTCH VanAtlanta
  • 4 weeks later...
