2002 c4 Cabriolet Tiptronic
I got the backup lights working!
The multifunction switch is attached to the shifter on the 2002 tiptronic. The switch is on the drivers side of the shifter and has two wire harnesses connected to it in the back. There are two screws one on the top front and one on the bottom rear of the switch. The one on the bottom rear is behind the two wire connector which is also for the back up lights. I took the switch off and cleaned it with electrical cleaner clicked it on and off and now the switch works and I have reverse lights. Saved $180 bucks in the process.
