If lowering with the Eibach pro kit springs (~1" drop), do you guy s re-use your OEM bumpstops, use none at all, or cut/trim/shorten and re-use the oem bumpstops? The setup is with aftermarket Ohlins dampers. Do these require usage of the oem bumpstops?
Edited by chaudanova
No trimming or modifications need to be done to the OE bumpstop for that application. Do the Ohlins dampers come with bumpstops? It might be best to email someone at Ohlins to find out.
