Hey. Im having problem getting the top to open or close. When I open the top latch, the windows drop but, thats as far as I get. I was reading earlier and I know the parking brake has to be up, but when I engage it, the light doesn't appear. Is that a possible fuse problem or is there more to it. Well any iformation would be appreciated. Thanks
Kyle
Kyle
Kyle:
No power will go to the electric motor that drives the convertible top transmission cables unless that parking brake light is lit.
If you want to check the fuses too, take a look at the Bentley manual (B3 and D6 IIRC).
Regards, Maurice.
You want to fix it but 99 in a pinch, sometimes you briskly yank the and brake up an down a everal times and get the light, ergo the top to work.
Regards, PK
