I've searched for someone with the same problem, but to no avail.
What I have is similar to what others have had, one side of the clam shell raises, while the other side stays put. I suspect, as others have found, that it is a broken cable, though I cannot see in there.
As I tried to manually loosen the clam shell to see if it was just stuck on something, the linkage between the shell itself and the mechanism broke.
Is this a dealer fix or can I order that specific part and install it myself?
Also, I do not see how to get to the linear actuators to pop them off to lower the top manually, I may be blind.
Edited by maytime
