Yes the 996 and 997 hardtops are essentially the same.
for 03 and later 996, and all 997s you will need to install the attachment hardware on the car.
Make sure you get the latest hardware. there is a TSB on upgrading the hardware to a "screw" type that reduces squeaks, etc. It will also show how to install the hardware. You may have to do a little wiring for the rear defroster as the connector may not be there, each wiring harness is custom made, but it won't be hard.
