hi
i have measured all height again and i suprised.
front left = 682mm
front right = 672mm
rear left = 655mm
rear right = 663mm
i'm ordering Euro M030 Sport Kit now, this kit include front bumpstops?
or should i order front bumpstops??
i have a 1999 C4 Cab 6speed US version Now.
thanks
Mick
i got this email below from carnewal
The M030 kit includes the rear bumps stops are they are different from the standard suspension.
The front bump stops are the same for the standard and the M030 suspension, for that reason, Porsche does not include them in their kits.
then, my last question is here. my 1999year porsche C4 Cab 6speed need new front bumpstops? because it is too old...???
Not likely - I would only replace them if they are damaged. They spring do nothing unless the suspension bottoms out.
996.343.301.02 Additional Spring -- US MSRP $17.77 each (1 required per shock)
