I have these 2 codes when i read them, P0103 & P1108. Some background info is i am using a boxster air filter housing with a 996 manifold and MAF. Also i deleted all of my cats to open up the exhuast for the 3.6L currently in there. The car is running kind of like poop and i loove to fix this. I fel like im missing out on some of the 3.6L power even though its still way faster than my old 3.2L. The car just seems to hesitate a lot and its feeling really weird at lower rpms. Thanks guys!
I have these 2 codes when i read them, P0103 & P1108 on my 3.6L (came from 2004 Carrera C4S) in my Boxster. Some background info is i am using a boxster air filter housing with a 996 manifold and MAF. Also i deleted all of my cats to open up the exhuast for the 3.6L currently in there. The car is running kind of like poop and i loove to fix this. I fel like im missing out on some of the 3.6L power even though its still way faster than my old 3.2L. The car just seems to hesitate a lot and its feeling really weird at lower rpms. Thanks guys!
Please do not double post - I have deleted your second post.
Anyone know? I have the P1108 code myself and cannot figure it out.
Loren has the correct info below......
Regards,
paul...
Edited by paulv
P1108 Oxygen Sensing Adaptation, Lower Load Range, Bank 2 – Below Limit
Possible fault cause
- Incorrect signal from MAF sensor
- Fuel pressure too high
- Fuel injector leaking
