I have a 2003 Boxster S with Tiptronic, factory sport exhaust, and about 22,500 miles. The Check Engine Light (MIL) came on. It drives fine with no noticeable problems. I bought the Durametric software and just came up with the following: "Code P0492, Fault code 208, Secondary Air System Bank 2." From the RennTech code info, it says that this is also "below limit." I reset the code and ran the car very briefly and the code did not re-occur right away. I suspect that it might come back in time.
Any suggestions on what this might be? Since I have the software, I can check various signal readings in operation.
Thanks in advance for any help.
Brent Smith
Atlanta, GA
Brent Smith
Atlanta, GA
P0492 Secondary Air Injection System, Bank 2 - Insufficient Flow
Possible cause of fault
- Electrical fault in power supply or line between relay and secondary air injection pump
- Secondary air injection pump relay mechanically faulty
- Mechanical fault in electrical secondary air valve
- Pneumatic secondary air valve faulty/sluggish
- Electrical fault in secondary air injection pump
- Mechanical fault in secondary air injection pump or secondary air injection pump blocked
- Vacuum system leaking
- Air hose to secondary air injection pump slipped off or constricted
When you first start the car do you hear the air pump (sounds like a small vacuum)?
If not - check to see that it's electrical connector is plugged in, check the fuse (40A fuse on relay panel 2), and then the relay (relay position 10).
Thanks for taking the time to respond, Loren! I will check things out and report back.
Brent
