I am doing the very common horn fix for my 4-spoke steering wheel. Can someone tell me where I should disconnect the aribag? On the yellow connector right on the back of the airbag? Or the wire connector that is attached to the back of the steering wheel? Thanks!
The small yellow connector on the rear side of the airbag is the one you need, disconnect the battery first and wait for 5 minutes before removing the airbag.
Success! Thanks for your help RFM
