Was looking at LSD for my 2008 BoxsterS and they did not offer this as a factory option in 08 apparently. I know they offer it in 2009 model. Does anyone think it would work on the 2008 S model?
You might want to try the Quaife Automatic TBD (Torque Biased Differential). It's a helical gear based differential which doesn't require much attention once it's fitted. Product code is QDF12Q. Actually for the Cayman S model as your car has the same engine and drivetrain.
Yes I have seen that and is probably what I will do. Will it work with the PASM suspension system?
