Hi All,
It was all going so well, i was on my way to replacing brake pads and discs on all four wheels....As soon as i got to the rear set i missed the step which tweaks the adjustment fixture behind the disc to release for easy removal of the disc. Instead i forced the issue and now the two retainer springs (one on each brake shoe) are loose and not holding the shoes in place with enough force. Im assuming i can simply replace these and readjust the parking brake after?
Is there anything else that could have been affected....how would i test that?
Any comments much appreciated.
car is a 2002 (996) carrera 4 - 3.6L
Hi All,
I think there are four springs total:
* two short tensions springs across the bottom, 997 352 721 01
* one long tension spring at the top, 997 352 723 02
* and the two compression springs, which it sounds like are the ones you stretched
- I think they are 997-352-741-01
Other than the shoes, the adjuster at the top and the lock thing at the bottom, that is about it. Not much to break. I bet you are OK except for the stretched springs. I assume you stretched them enough that the shoes are hanging a bit loose?
You are spot on, they are hanging a little. Cant wait to contact Porsche in the morning after the easter weekend and get hold of a pair.
Thanks very much for the help.
I broke these same springs by putting too long of wheel bolts without my spacer by accident.
Have you called the dealer yet? $30 per spring for something that could only cost $.50 in any real world. I went to Autozone and asked to look at their hardware packages for drum brakes and the second one I picked up had retainer springs that fit perfectly. The pack with 4 retainer springs and a bunch of other springs was $8.50.
When you install them, I highly recommend you use a mirror of some kind (I used a dental one) to make sure the hook part of the spring is properly seated in the grove in the hub carrier. Otherwise they could pop out and that's not good.
Wish i had seen this post earlier.....i did end up buying the springs from the local Porsche dealer and it did cost a ridiculous amount. I also agree with your comment about the dental mirror....it was a real pain to make sure the went in properly.
Appreciate the advice, my pride and joy is road worthy once again!
