Ok all, I have heard people reference the back seat access panel several times.
I have looked back there and I do not see an obvious panel.
How do you access this?
Thanks all
if you are referring to the panel behind the seats on the front side of the engine, then you need to:
- put the top in service position
- remove the speaker/cubby box or storage bag (if present)
- remove the carpet over the engine cover
- remove the 4 plastic nuts just under the roll bar holding the carpet up on the back wall
- pull the carpet off from the firewall
which will reveal the access panel (silver aluminum here) shown here.
It's held on w/ seven 10mm bolts and two 10mm nuts if I recall correctly. When/if removing, wear gloves or be extra careful as the edges of the panel are extremely sharp.
Edited by Cassiebox
