I have a 04 Cayenne S and just got the Air Bag Fault Light. I know I need to either go to the dealer to have the light reset or buy the Durametic. But what would be the "likely" cause? I live in Ontario Canada and this is my daily driver, so I guessing corrosion on one of the seat or seatbelt connections.
On a sort of related note my brake pad indicator has come on and i am planning on doing the brakes myself. Will that light reset automatically or will I need the Durametric for that as well?
Dan Haddock
06 Silver Cayenne S
What is the fault code? (it will pinpoint where the problem is)
Brake pad wear sensors are just wires that when worn trough turn on the light - so if your pad sensor light goes on you will need new sensors.
I haven't got the code yet. I assume I have to go to the dealer for that or buy the Durametric. Is that correct or is there another way to get the code?
Yes, you will need the Durametric software or a PIWIS tester to ge the air bag fault code(s).
