so, I'm close to retrofit OEM Xenon Headlights into my PCS. I've got almost everything but I dont have the mounting support. I would like to know if there is any difference between the non xenon headlights mounting support and the xenon ones? because mine are bad I would like to change them and the request is to provide me the right code in order to get the ones that I need for Xenon headlamps. Iknow I should have been able to find them but I cant find the difference between codes :(
here is the picture of what I need, remember for the XenonHeadlamps:
thanks in advance Loren :)
There are the same part number for both standard and Xenon.
thought that are the same but from what I've got there are like 3 different types:
first picture and the second one where this one is the 16th and then 20th piece, are the same codes but three of them?? why, and more important which are the differences between them:
A 955 631 041 00 mounting - L
A 955 631 041 01 mounting - L
955 631 041 02 mounting - L
A 955 631 042 00 mounting - R
A 955 631 042 01 mounting - R
955 631 042 02 mounting - R
and offcourse what should I get?
thanks again Loren,
All part numbers that start with "A" have been replaced. Use the newest part.
got that.
since the pet file that I have isn't updated, can you check please if these are the latest codes:
thanks again,
Ilie
Yes, those are the latest part numbers (and the only ones currently available).
thanks Loren,
