In checking the foam trays and drain tubes for my top drains, I did the method of pouring a measured amount of water down the hole. The tubes don't stick out the bottom of the car quite far enough, so the first of the water to come down kinda dribbled across the bottom of the car til the flow carried it out of the hole. I got about 9 / 10ths of what I poured down, but the rest ran sideways across the undercarriage. Should the tubes stick down and actually "Out" of the car? Or is this normal?
