I apologize for this question, but I just bought a 2002 Carrera Cabriolet, Tiptronic and I can't find a switch to manually raise the wing. Is there none?
the fuse box is located down on the right side of the foot well on the drivers side ... if you look at the cover on the fuse box you will see a black switch .. this switch when pressed upwards will raise spoiler press the lower part will lower the spoiler ignition or engine needs to be on for this to work ..
its a rocker switch its the only switch on the fuse box panel ..
